New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
ESRI to JMP Map Converter
jeffmoore
Level I
This add-in takes ESRI map shape file pairs as input and creates JMP maps.
Updated on 7/14/2014
Fixed a problem where the converter would hang on a certain type of ESRI shape file.
Comments
Austevie
One of my favorite add-ins!   Makes mapping census geographies not including with JMP a piece of cake.  I use it all the time for census tract data!
