eurvan
Covid 19 worldwide dashboard
Here is an addin that uploads actual data from J.Hopkins University and generates automatically a dashboard with worldwide cumulative cases, deaths and recovery // new cases, new deaths and new recovery per day. Simply download the addin and install it in JMP.
Comments
I just wanted to let you know that there appears to be a stacking issue with the John Hopkin's Dashboard Data. When running the add-in there is a mismatch of column labels and data. Is it possible that this is a version issue (JMP 14)?
Hello Todd, it should work on JMP 14 too. I have test it.
