November 2017: note from the author:
This add-in may not work as intended on MacOS.
This add-in is designed to produce an attractive graphical rendition of a process capability study, and to make it easy to perform analyses across multiple columns of data.
NEW!
Version 3.00 of the add-in introduces a thumbnail previewer.
The thumbnails can be arranged vertically or horizontally.
The vertical arrangement is designed to sit next to the main window whilst the horizontal layout is intended to fill the full screen.
Hover over a thumbnail to view Cp/Cpk indices
Click on a thumbnail to view in the main window
As with app-stores, ratings are a useful mechanism for users to voice their requirements and for developers hear what is and what is not useful. Based on number of viewings this is probably my most popular addin - but is it actually used or useful - with zero ratings and comments I have no idea.
As the release of version 12 of JMP approaches I'll be making a decision as to whether or not I will discontinue supporting this add-in. Currently I have no reason to continue with it, so please if you are using it and would like to have it maintained for future versions of JMP please let me know.
This is excelent! nice Add-in very useful since simplifies some steps when data is analyzed.
Thanks kely. It's been a time since I've updated it so if you find any problems or have ideas for improvements please let me know as I'll be looking at issuing an update over the next few months.
Dave
How about add-in for JMP standard edition?
It ought to work with standard JMP
Useful tool for process capability, thank you. I'd like to see it report the Ppk indices as this has quickly become a more functional indices for larger sample sizes over time.
Kindly,
Will
Does this work on JMP 13?
I have found it to be very useful tool, I think it would be advantage if option is provided to upload specficiations limits.
