JMP Add-Ins
Anonymise Continuous Column Ranges to -1 to 1
This add-in takes a continuous column and scales the column range to between -1 and 1. This enables extra anonymization to your data (in addition to Tables > Anonymize).
Simply select columns you wish to scale and either select in Add-Ins or hit Ctrl + Alt + A (Windows) and extra column(s) with the selected column name + "_anon" will be added to the data table.
