JMP Add-Ins
Download and share JMP add-ins
Animated 3D Spider Model
Afternoon project, just for fun.  Uses JMP's OpenGL interface and Scheduler.  Use your mouse to rotate the scene.  The shadow is created by squishing a second copy of the model and placing it just above the floor.  The checkerboard is not much larger than it appears; the fog is set to hide the edge.  This would make a great villain to go in the rat maze example that ships with JMP, but someone would have to make spider do more than walk in place.
Comments
jim_lamar
Look underneath the "table" and you can see the spider's legs poking through . . . pretty cool
