Submit your abstract to the call for content for Discovery Summit Americas by April 23. Selected abstracts will be presented at Discovery Summit, Oct. 21- 24.
Discovery is online this week, April 16 and 18. Join us for these exciting interactive sessions.
Add-in to copy graph without window background
julian
This add-in adds a menu item (under the Add-ins menu) to copy the currently selected item in JMP without the default window background. This is especially useful when copying graphical output to a document with a white background (such as publications and websites).
Instructions for use:
1. Install add-in by double-clicking downloaded file.
2. Select a graph using the selection tool (fat plus sign).
3. Select "Copy without background" from add-in menu.
4. Paste graphic to desired program.
Comments
juliaaline
Thanks a lot that is a great help!
rcookie
Hi @julian ,
Thanks for the add-in, this definitely helps.
I have noticed JMP15 automatically copies the background although JMP14 did not, do you know if this is on purpose or if it is a bug that will be fixed?
Thanks,
Richard
@martindemel
 @rcookie I guess it is due to a preference setting in JMP (though I guess the add-in tries to set it?):transparentBackground.JPG
Does changing this setting change something with the output too?
rcookie
@martindemel yes it is, perfect!
I'm not sure the add-in actually sets this preference, but in any case this setting does remove the background even for other image formats than PNG (windows metafile for example).
Thanks for your help
Richard
Urs
Hi,
This is a great tool. However, I think it creates a problem with dark-mode on OS X. After copying a figure without background, the background of all the column headings turned white.
How can I un-install this add-in?
Thanks
Urs
Hi Urs,
under the View Menu go to Add-Ins, in the window appearing select the add-in you want to remove and press the button Unregister. This will ask you if you want to delete it also from the folder or just remove it from JMP.
Best, Martin
