Getting Started
Learn how to use the JMP User Community effectively
Getting the most from your post: Using the JSL Syntax Highlighter
Use the JSL syntax highlighter to enable formatting, syntax recognition, more readable and interpretable output.
You can add highlighted JSL code to your post.
1. Click the Insert JSL Script icon:Use JSL button to insert formatted codeUse JSL button to insert formatted code
2. A box opens. Type or paste your JSL script in the box.
3. Post.
Note: The highlighting will not appear in preview mode.
Next: Return to Getting Started
