what is the sign function
pmroz
Re: what is the sign function
There doesn't appear to be a sign function in JSL.  Do you need a sign function?  Something that returns 1 for positive, 0 for zero, and -1 for negative?  Here's one solution:
Function Name: sign
Description: Returns 1 if positive, 0 for zero, -1 for negative
Arguments:
one_number    Number to test
sign = function( {one_number},
        {Default Local},
    sign_value = .;
    if (!is empty(one_number),
        if (one_number > 0,
            sign_value = 1,
            one_number == 0,
            sign_value = 0,
            one_number < 0,
            sign_value = -1
// Return the sign value
     sign_value;
Sample usage:
a = sign(47);
print(a);
b = sign(0);
print(b);
c = sign(-999999);
print(c);
Yields the following in the log window:
1
0
-1
pmroz
Function Name: sign
Arguments:
        {Default Local},
    sign_value = .;
        if (one_number > 0,
            sign_value = 1,
            one_number == 0,
            sign_value = 0,
            one_number < 0,
            sign_value = -1
     sign_value;
Sample usage:
a = sign(47);
print(a);
b = sign(0);
print(b);
c = sign(-999999);
print(c);
1
0
-1
Thanks PMroz, works great.
Gene
