UserID16644
Level V
unrecognized as table argument in access For loop
I am trying to concatenate my subset tables, but I kept getting this error:
unrecognized as table argument in access or evaluation of 'dtSubsetList [ /*###*/i]' , dtSubsetList [/*###*/i]
Im using JMP 16
names default to here(1);
dtSubsetList = dt << Subset(
	By( :sex ),
	All rows,
	Selected columns only( 0 ),
	columns( :name, :age, :height, :weight )
dtNew = New Table( "New Table" );
For(i = 1, i <= N Items(dtSubsetList ), i++,
dtNew << Concatenate(dtSubsetList[i], Append to first table(1));
Re: unrecognized as table argument in access For loop
I am unable to replicate the issue.  Your script runs properly without error.
I suggest that you exit JMP, and then reopen it and then run the script.  Your dt_Test is obviously not in the JSL you provided, and is probably an artifact of all of the trial and errors you have attempted.
I will also suggest a change to your code.  The Concatenate platform has the ability to concatenate more than one table in a single execution.  Therefore you can actually past the complete list of data table to the Concatenation rather than having to loop through each one separatly.
	By( :sex ),
	All rows,
/*For( i = 1, i <= N Items( dtSubsetList ), i++,
	dtNew << Concatenate( dtSubsetList[i], Append to first table( 1 ) )
dtNew << Concatenate( dtSubsetList, Append to first table( 1 ) );
