text in the filtre
How can I add text to the filters to explain them better?
Re: text in the filtre
Is this what you are looking for?
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
Open( "$SAMPLE_DATA/Big Class.jmp" );
New Window( "Oneway Analysis",
	V List Box(
		Text Box( "    Please Click on the Age" ),
		Text Box( "    Value to Change the Analysis" ),
		Text Box( " " ),
		Oneway(
			Y( :height ),
			X( :sex ),
			Means( 1 ),
			Mean Diamonds( 1 ),
			Local Data Filter( Add Filter( columns( :age ), Display( :age, N Items( 6 ) ) ) )
I like Jim's suggestion, but here's another that might work. Change the title of the Local Data Filter. You can click on the title twice to enter edit mode, then type another title.
Using JSL, it would be:
Oneway(
  Y( :height ),
  X( :sex ),
  Means( 1 ),
  Mean Diamonds( 1 ),
  Local Data Filter(
    Title( "Choose age(s) to display" ),
