JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
Created:
Mar 25, 2021 04:22 AM
| Last Modified: Jun 10, 2023 4:27 PM(3445 views)
I try to sum Column 1+Column 2+Column 3 in a seperate column by using formula option of jmp. But sometimes some rows results are empty. due to that formula editor is not calculate the result. Could you please help for it?
Please find enclosed jmp file as an example to explain my issue.
