MFVIT
standard deviations in one way analysis of variance with blocks
I used the fit y by x platform of JMP to analyze the effect of two products on a response. I also have a blocking variable. The block means report is the following:
Means and Std Deviations
Level Number Mean Std Dev Std Err Mean Lower 95% Upper 95%
A              52   3.75 0.563468 0.078139 3.631591 3.945332
B             52   3.97 0.563468  0.078139 3.7854372 4.0991782
Why are standard deviations the same (the actual standard deviations estimated from each sample are different)? What is the formula behind
Many thanks.
Re: standard deviations in one way analysis of variance with blocks
A primary assumption of the ANOVA model is that the errors are constant across all groups. So the 'sum of squared errors' are 'pooled' across all groups. The estimates are not the simple standard deviation of each group as you would get from Distribution with By( group ) role.
The same assumption is made by the two-sample t-test, unless a correction is made.
MFVIT
Thank you for your response.
I understand your point. When the Means and standard deviations command is selected in the JMP Fit Y by X platform, the results depend on the use of the blocks. If blocks are not used the group standard deviations are calculated while if a block effect is added the standard deviations are calculated as you said.
