ron_horne
size to isometric - is it scriptable?
hi All,
Is there a script command i can write to produce a graph with isometric scale?
When I make a graph and select "size to isometric" the script it produces does not insure an isometric graph if the data has changed.
thanks!
ms
Super User (Alumni) ms
Re: size to isometric - is it scriptable?
Send the command to the FrameBox.
For example:
biv = Bivariate(Y(:weight), X(:height));
Report(biv)[FrameBox(1)] << size to isometric;
ms
For example:
ron_horne
Thanks! i was looking for that for a while.
