jearls11
selecting first 5 numbers of a value and matching them with another column
hi folks,
i want to do a new column, if the first 5 digits in batch_id are the same as the first 5 in batch_id_1 then true else false.
I can do the if statement but not sure how to select the first 5 digits.
Re: selecting first 5 numbers of a value and matching them with another column
You can use Left() to get characters from the start of string
a = "123456789";
five_char = Left(a, 5);
show(five_char);
a = "123456789";
show(five_char);
