  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
cz1
cz1
script - delete or reorder colums
hi,
I would like to add "delete multiple columns" or "reorder multiple columns" to my script.
How can I code this into my scripts?
JMP help provides a simple description for a single column, but I can't do it manually for more than 100 columns.
Thank you in advance
A++
 Zdenek
dt:height << Set Selected;
Wait(2);
dt << Delete Columns();
Edit (jthi): added jsl formatting
Re: script - delete or reorder colums
Do you wish to reorder/delete columns based on user-selection or list in the script?
Using list (Delete Columns )
cols_to_delete = {"height", "weight", "age"};
dt << Delete Columns(cols_to_delete);
Selection
dt << Select columns(cols_to_delete);
Reordering
cols_to_reorder = {"height", "weight", "age", "name"};
dt << Move Selected Columns(cols_to_reorder, To Last);
JMP's Scripting Index does sometimes have nice examples so it is a good starting point when scripting JMP.
