lgutierrez
saved script format new table correctly, but no data is loaded
Hi all,
JMP 18.0.1 in Windows
Super beginner here. I'm trying to use scripts in order to save time formatting and analyzing data. I save a script from a dataset A via "red triangle > copy table script" and dump it in a text editor. Then I open the dataset B (exactly same original formatting as dataset A) and go "red triangle > new script", and paste the table script. The result is that I get a the proper formatting and new column formulas, but no data is loaded (as seen below)
How can I make use of the script from dataset A to generate a formatted/analyzed dataset B? I tried modifying the references in the script but it made no difference.
Kind regards,
Re: saved script format new table correctly, but no data is loaded
What does your A dataset have? What does your dataset B have? What do you wish to copy over from dataset A to dataset B?
Also, you might want to check out Workflow Builder https://www.jmp.com/support/help/en/18.0/index.shtml#page/jmp/workflow-builder.shtml# .
lgutierrez
Thanks for your quick reply.
dataset A and B contain measurement results of two different devices, in csv format. I proceeded to manipulated A to stack columns, add new formula columns, etc.. in order to produce the result graphs I need. I see the A script contains the steps followed to achieve the final format.
What I'd like is to use this script to simplify/speed up the formatting of B, so I can go straight into data analysis. I have dozens of other datasets to be analyzed, all with the same raw format, so being able to reach proper format by one mouse click would go a long way.
I'll look into the workflow builder.
Also, what messages are in the log?
providing the script would be very useful.
