shampton82
save an analysis script to the data table without running it first
is there a way to save a script to a data table without running it?
I use this to save an analysis after it gets ran:
objgb1 << Save Script to Data Table( "GB", <<Prompt( 0 ), <<Replace( 0 ) )
but I'd like to set up the analysis then have it save to the table so a users can run it later on if they need to.
Thanks for any ideas.
Steve
Re: save an analysis script to the data table without running it first
Most likely there are other options, but here is one
fit = Expr(Bivariate(Y(:NPN1), X(:PNP1)));
Eval(EvalExpr(dt << New Script("FitX-Y", Expr(NameExpr(fit)))));
Any analysis script can be saved directly to the data table, without running it
Current Data Table() << new script(
	"theDistribution",
	Distribution(
		Continuous Distribution( Column( :weight ) ),
		Nominal Distribution( Column( :age ) )
	"theDistribution",
	Distribution(
