heena
run jsl script from command line in linux
Dear community,
I am very new to jmp. i want to use on linux. I have installed jmp on my mac and generated script file. i have many questions
1> how i can install jmp on linux. on this page (http://www.jmp.com/support/system_requirements_jmp.shtml) they say they have linux version but can't find anywhere
2> what is the command for running script from command line? I am familiar with R.i used to run command for r script like this
     Rscript script.R  "output.pdf" "/data.csv"
how i can of this for JMP script on command line?
3> how i can access command line parameter in script? for eg
     in R if i ran this command Rscript script.R  "output.pdf" "/data.csv"
     i can get output.pdf and data.csv like this
     args <- commandArgs(TRUE)
     pdfname <- args[1]
     datafile <- args[2]
how i can do in jsl script?
Any help would be much appreciated.
Many thanks.
Jeff_Perkinson
Re: run jsl script from command line in linux
JMP is not available for Linux.
The system requirements listed on the page referenced are for an older version that is no longer distributed.
-Jeff
-Jeff
