Françoise
rename cell
hi,
I've wrote this jsl to rename cell with"portion" by "Portion".
It's doesn't work.
has someone a solution?
dt= Current Data Table();
For( I = 1, I <= N Rows( dt ), I++,
if(dt:Format == "portion",
dt:Format == "Portion"
best regards
Re: rename cell
Your script needs to be updated to point directly to the row you want to evaluate and to change
dt = Current Data Table();
	If( dt:Format[I] == "portion",
		dt:Format[I] = "Portion"
A more efficient way of coding this is:
dt:Format[dt << get rows where( :Format == "portion" )] = "Portion";
Françoise
Re: rename cell
Ok, it's good !
thanks
Re: rename cell
Françoise
Re: rename cell
Ok, it's good !
thanks
