Odellve
regex question regarding list check column property
Is there any way to use regex in a column List Check property?
Re: regex question
I think this still holds true Regular Expression in List Check? and only list of values can be used. No idea if wish list item has been posted.
Using JMP > Set JMP Column Properties > Column Properties in JMP > Properties That Validate Column ... and look for List Check
