mjoner
"Dynamic Reference Line"?
Is there a way to modify a Profiler so that when certain variables are changed, a y-axis reference line is drawn at a specific location?
More specifically I have a Profiler modeling y = f(x,z) where x are control variables and z are variables that are usually noise but which I can control in the right environment. I have a comparison/reference value y' = g(z) and know that the reference will change if certain noise variables increase or decrease.
Right now the only way I can think of to do this is to create a Profiler on (y-y') by making a new formula, but then my end users have to know that the y-variable in this new Profiler is not measuring raw outcome but is rather measuring the delta of y relative to the reference, and I worry that this could be confusing. Are there other options?
David_Burnham
Re: "Dynamic Reference Line"?
Not sure this is helpful or not depending on if I understood your question
The Set Script message for the profiler allows you to assign a callback function which is invoked whenever a variable is changed.  Below I set the ref line to be 50 times the value of the "Silica" whenever a variable is changed
dt = Open( "$SAMPLE_DATA/Tiretread.jmp" );
prof = Profiler(
    Y(:Pred Formula HARDNESS),
        Dispatch(
            {"Prediction Profiler"},
            "10000",
            ScaleBox,
            {Min( 100 ), Max( 20 ), Inc( 5 ), Minor Ticks( 1 )}
prof << Set Script( CallBack() );
CallBack = Function({settings},{Default Local},
    silicaValue = Get Silica(settings);
    show(silicaValue);
    rep = prof << Report;
    refLineValue = 50*silicaValue;
    Try(
        rep[AxisBox(1)] << Remove Ref Line(::lastValue)
    rep[AxisBox(1)] << Add Ref Line(refLineValue);
    ::lastValue = refLineValue;
Get Silica = Function({settings},{Default Local},
    For (i=1,i<=NItems(settings),i++,
        item = Char(settings[i]);
        varName = Word(1,item," = ");
        If (varName == "SILICA",
            value = Word(2,item," = ");
    Num(value)
-Dave
David_Burnham
prof = Profiler(
        Dispatch(
            "10000",
            ScaleBox,
    show(silicaValue);
    Try(
    Num(value)
-Dave
orel
hi
i have a question about the dynamic issue:
i want to add  a parameter into the profiler that will be calculated from the data that are in the profiler and are changing.
for example - the flow rate is a function of viscosity which is changing according to grinding time. if i could add a formula into the profiler it will calculate the flow dynamically.
can you add the formula into the profiler?
thanks
orel
