voy-voy
open multiple Journals
I look for a script, where I can open multiple Journals, and ad to different points in script an object to the chosen Journal.
With my script the diagrams are always in the last opened Journal, not in the Journal I choose.
Could someone help me to solve the problem?
dt = Open("C:\Program Files\SAS\JMP\17\Samples\Data\CrimeData.jmp");
///Journale Erstellen
J1 = New Window( "xxx1", <<Journal );
J2 = New Window( "xxx2", <<Journal );
J3 = New Window( "xxx3", <<Journal );
df = dt << Data Filter(
	Speicherort( {646, 247} ),
	Modus( Anzeigen( 1 ), Einschließen( 1 ) ),
	Filter hinzufügen( Spalten( :Year ), Where( :Year >= 2000 ) )
); ///Last 20 Yeras
Dia1 = Bivariat( Y( :Property Rate ), X( :Year ) );
Dia2 = Bivariat( Y( :Robbery Rate ), X( :Year ) );
Dia3 = Bivariat( Y( :Rape ), X( :Year ) );
J1 = current journal();
Dia1 << journal;
J2 = current journal();
Dia2 << journal;
J3 = current journal();
Dia3 << journal;
df << Close;
dt << Clear Selection();
df2 = dt << Data Filter(
	Filter hinzufügen( Spalten( :Year ), Where( :Year >= 2005 ) )
); //////Last 10 Yeras
Dia1a = Bivariat( Y( :Property Rate ), X( :Year ) );
Dia2a = Bivariat( Y( :Robbery Rate ), X( :Year ) );
Dia3a = Bivariat( Y( :Rape ), X( :Year ) );
Dia1a << journal;
Dia2a << journal;
Dia3a << journal;
Re: open multiple Journals
I think this is the most straight forward way to handle this
dt = Open("$SAMPLE_DATA\CrimeData.jmp");
///Jornale Erstellen, damit die Diagramme direkt wieder eingefügt werden könenn
J1 = New Window( "xxx1", <<Journal, vlb31 = vlistbox() );
J2 = New Window( "xxx2", <<Journal, vlb32 = vlistbox() );
J3 = New Window( "xxx3", <<Journal, vlb33 = vlistbox() );
); ///Last 20 Yeras
Dia1 = Bivariate( Y( :Property Rate ), X( :Year ) );
Dia2 = Bivariate( Y( :Robbery Rate ), X( :Year ) );
Dia3 = Bivariate( Y( :Rape ), X( :Year ) );
vlb31 << append(report(dia1));
vlb32 << append(report(dia2));
vlb33 << append(report(dia3));
df << Close;
Dia1a = Bivariate( Y( :Property Rate ), X( :Year ) );
Dia2a = Bivariate( Y( :Robbery Rate ), X( :Year ) );
Dia3a = Bivariate( Y( :Rape ), X( :Year ) );
vlb31 << append(report(dia1a));
vlb32 << append(report(dia2a));
vlb33 << append(report(dia3a));
); ///Last 20 Yeras
df << Close;
voy-voy
Thank you, it works perfectly :)
