hogi
Level XIII
non-grouped column names
After grouping several important columns, I want to hide the remaining columns in the "attic".
How do I get a list of all non-grouped columns?
Re: non-grouped column names
Get list of all columns, get list of grouped columns and drop grouped from the list of columns
// Setup
dt = Open("$SAMPLE_DATA/Cities.jmp");
dt << group columns("xy", {:X, :y});
dt << group columns("pollutants", :Ozone :: :Lead);
collist = dt << Get Column Names("String");
grouped_list = {};
For Each({groupname}, dt << get column groups names,
	c = dt << get column group(groupname);
	groupcols = Transform Each({cr}, c, cr << get name);
	Insert Into(grouped_list, groupcols);
nongrouped = Set Difference(collist, grouped_list);
For Each({colname}, nongrouped,
	Column(dt, colname) << Hide(1);
wait(0);
// Setup
grouped_list = {};
wait(0);
hogi
Level XIII
The detour via strings makes sense : )
I wonder why is it necessary ...
// Setup
dd= dt << group columns("xy", {:X, :y});
ee= dt << group columns("pollutants", :Ozone :: :Lead);
Type(ee)
collist = dt << Get Column Names();
grouped_list = {};
groups= dt << get column groups names;
For Each({groupname},groups,
	groupcols= dt << get column group(groupname);
Show(grouped_list); // list of names with ":" {:OZONE, :CO, :SO2, :NO, :PM10, :Lead, :X, :Y};
show(collist);// list of names without ":" {city, Latitude, Longitude, ... }
nongrouped = Set Difference(collist, grouped_list); // ?!?! {city, CO, Latitude, Lead, Longitude, Max deg. F Jan, NO, OZONE, PM10, POP,"pop- m"n, Region, SO2, State, X, Y}
details which are important to know:
  • The return value of of << group columns is a string - not a column group.
  • << get column group returns a list of columns, not a column group
  • important: THIS list of columns lists the names with leading ":"
  • compare: get column names() returns a list of names without the leading ":"
  • -> the two lists are not compatible with each other
Workarounds:
  • via String
  • via columns
convert to list of columns = Function ({myColList},
	Transform each({col},myColList, Name Expr(As column(dt, col)))
grouped_list = convert to list of columns(grouped_list); // looks like before, but is something completely different
collist = convert to list of columns(collist); //{:city, :Latitude, :Longitude, ... }
Show (nongrouped) // {:city, :Latitude, :Longitude, :Max deg. F Jan, :POP, :"pop- m"n, :Region, :State};
When I'm dealing with columns, only thing I care about is to get them all to strings as it will avoid a massive amount of issues you will have otherwise. In my opinion, there are basically zero reason to try and deal with columns initially with anything else than strings as you can always go from string to other "column formats". And, if  there is a reason to start from something else than a string, it isn't worth it in my experience.
