dadawasozo
Level V
no output on column formula with For loop and if() to count repeated str in cells
Hi, Below (section A) is my code for a formula in a new column and it is working. However, I want to use for loop to replace it. I tried on it(Section B) , but there is not output at all. I wonder if someone can give me some advice of my mistake on section B? the example of column smap1 is in attached table. Thanks
section A:
dt3 << new column("smap", character,
formula(
	If(N Rows( Loc( Words( :smap1, "," ), "0" ) ) >= 3, "0:0:0:0:0:0:0:0",
	   N Rows( Loc( Words( :smap1, "," ), "1" ) ) >= 3, "1:1:1:1:1:1:1:1",
	   N Rows( Loc( Words( :smap1, "," ), "2" ) ) >= 3, "2:2:2:2:2:2:2:2",
	   N Rows( Loc( Words( :smap1, "," ), "3" ) ) >= 3, "3:3:3:3:3:3:3:3",
	   N Rows( Loc( Words( :smap1, "," ), "4" ) ) >= 3, "4:4:4:4:4:4:4:4",
	   N Rows( Loc( Words( :smap1, "," ), "5" ) ) >= 3, "5:5:5:5:5:5:5:5",
	   N Rows( Loc( Words( :smap1, "," ), "6" ) ) >= 3, "6:6:6:6:6:6:6:6",
	   N Rows( Loc( Words( :smap1, "," ), "7" ) ) >= 3, "7:7:7:7:7:7:7:7",
	   "0:1:2:3:4:5:6:7"
section B:
formula(
map={"0","1","2","3","4","5","6","7"};
for (l=1, l<=N items(map), l++,
	A=":"||map[l];
	B=map[l];
	If(N Rows( Loc( Words( :smap1, "," ), char(map[l])) )>= 3, concat(B,A,A,A,A,A,A,A),
	"0:1:2:3:4:5:6:7"
ErraticAttack
Re: no output on column formula with For loop and if() to count repeated str in cells
Your formula is returning an Empty() value.  The For() loop exits when l = 9.  The logic is that when l = 8 the loop returns to the incrementor then the test.  The test for l <= N Items( map ) fails, returning an empty value.  What you need to do is to terminate the loop at the point the If() statement is true, then return the result.  Here is an example:
dt3 << New Column( "smap",
	character,
	formula(
		res = "0:1:2:3:4:5:6:7";
		For( l = 0, l < 8, l++,
			If( N Rows( Loc( Words( :smap1, "," ), Char( l ) ) ) >= 3,
				res = Concat Items( Repeat( Insert( {}, Char( l ) ), 8 ), ":" );
				Break();
		res;
Jordan
ErraticAttack
	character,
	formula(
				Break();
		res;
Jordan
