paul_apicella
locate value and replace them
Hi everybody,
I have this type of data table (see attached file). I want to detect all values which are outside of 2 threshold values (-0.5 and 0.5) and replace them by the ceiling values. For example: -5.30, -6.00, -11.56 must be replaced by the same value of -5.00, and 5.30, 6.00, and 11.56 replaced by 5.00.
Have you any suggestion to do that in a simple way ?
Thanking you in advance
ms
Super User (Alumni) ms
Re: locate value and replace them
If you think about doing this with JSL there are several ways.
For example, you could simply loop over the columns and conditionally replace cells
dt = Data Table("test.jmp");
For(i = 8, i <= N Col(dt), i++,
    ur = dt << get rows where(Column(dt, i)[] > 0.5);
    lr = dt << get rows where(Column(dt, i)[] < -0.5);
    Column(dt, i)[ur] = 5;
    Column(dt, i)[lr] = -5;
An alternative (JMP 13) is to work with data tables as matrices using subscripts. The syntax also supports assignment, i.e. replacement of cell values. Here's an example:
t = 0.5;                  // Treshold value
c = 5;                    // Ceiling value
nr = N Row(dt);
nc = N Col(dt);
M = dt[1 :: nr, 8 :: nc];// Matrix with all cells from col 8 to end of table
U = M <= t;              // Below upper limit?
L = M >= -t;             // Above lower limit?
//Assign treshold values to data table
dt[1 :: nr, 8 :: nc] = M :* (U & L) + c * (!U - !L);
ms
nr = N Row(dt);
nc = N Col(dt);
paul_apicella
Thank you very much MS,
Your first option works very well !
PA
