David_Burnham
k fold crossvalidation in the partition platform
... has it really been removed from version 16 of JMP ... I don't see it anymore?
-Dave
Re: k fold crossvalidation in the partition platform
It hasn't been removed, but you cannot  see it in red triangle anymore (no idea why).
dt = Open("$SAMPLE_DATA/Car Poll.jmp");
obj = dt << Partition(
	Y(:country),
	X(:sex, :marital status, :age, :type, :size),
	Split Best(2)
obj << K Fold Crossvalidation(5);
Also you can see it in preferences:
But if you enable it, it will launch every time.
Also: Bring back the crossvalidation option in Partition platform menu
	Y(:country),
	Split Best(2)
K-Fold of a partition model can be done using the Model Screening platform. K-fold is done in a more useful way there.
It was removed from the Partition platform because the folds were not independent of the tree-cut decisions. This can lead to overfitting of the tree model, especially prior to version 15. Steps were made to correct this in v15, but still not satisfactorily. Instead, better functionality was placed in the Model Screening platform.
Dan Obermiller
The deprecation was not mentioned in JMP 16 but this change is not mentioned in the New Features document. It is noted in the Scripting Index with the message syntax.
