Kevin
join two tables different row numbers
I have a question of how to merge two tables with different row numbers.
The first table is
TimeTool
182
182
193
193
The 2nd table is
TimeTool
185
198
The final Table I want is
TimeTool
185
185
198
198
Re: join two tables different row numbers
Interactively, you would just run the Join platform
     Tables==>Join
and specify to match based upon Time.
Below is a script doing the same thing as the interactive actions would do
// Create the first table
dt1 = New Table( "Table 1",
	Add Rows( 4 ),
	New Column( "Time",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [18, 18, 19, 19] )
	New Column( "Tool",
		Numeric,
		"Continuous",
		Set Values( [2, 2, 3, 3] )
// Create the second data table
dt2 = New Table( "Untitled 10",
	Add Rows( 2 ),
	New Column( "Time",
		Numeric,
		"Continuous",
		Set Values( [18, 19] )
	New Column( "Tool",
		Numeric,
		"Continuous",
		Set Values( [5, 8] )
// Join the 2 tables
dt3 = dt1 << Join(
	With( dt2 ),
	Merge Same Name Columns,
	By Matching Columns( :Time = :Time ),
	Drop multiples( 0, 0 ),
	Include Nonmatches( 0, 0 ),
	Preserve main table order( 1 )
     Tables==>Join
	Add Rows( 4 ),
	New Column( "Time",
		Numeric,
		"Continuous",
	New Column( "Tool",
		Numeric,
		"Continuous",
	Add Rows( 2 ),
	New Column( "Time",
		Numeric,
		"Continuous",
	New Column( "Tool",
		Numeric,
		"Continuous",
dt3 = dt1 << Join(
	With( dt2 ),
Kevin
Thank you, it works!
