CSkjodt
insert string from textbox in SQL statement in JSL script
Hi, I am taking my first stab at a jmp application.
I would like to insert a string from a textbox in a SQL statement used for a JMP query to a database. This string is my search parameter.
The script I have made does not seem to work and the solution is probably straight forward - but I am missing some basic JSL syntax understanding and was hoping to get help getting past this, for me, crucial point.
The script for calling and getting the string:
parameterScript = Function( {this},
    {text},
// This function is called when the Text Edit Box value is committed
    input = this << Get Text
The script for querying the database:
importDataPress = Function( {this},
// This function is called when the button is pressed
    name = New SQL Query(
        Connection( "ODBC:DSN=DATABASE;PWD=XXX;" ),
        QueryName( "my_table" ),
        CustomSQL( "SELECT * FROM DATABASE WHERE parameter == \!" + input + \!";" )
    ) << Run;
    <<Get Button Name;
Thank you !
Re: insert string from textbox in SQL statement in JSL script
You should start this by building smaller blocks and learning the syntax (how to concatenate strings in JMP, how namespaces/functions work, and so on)
Some material suggestions:
JSL Syntax Reference
JMP15 Scripting Guide
Scriping Index found from JMP Help menu
Very short example (check log when you change text in the window):
importDataPress=Function({this},
	retVal = this << get text;
	sqlString = "select * from * where " || retVal;
	Show(sqlString);
win = New Window("Example", Text Edit Box("Example Text",
	<< set function(
		function({this},
			importDataPress(this)
pmroz
Try something like this.  Note the use of evalinsert, panelbox, hlistbox, etc.  Look them up in the scripting index for more information.
importDataPress = Function( {parameter_value},
	sql_statement = evalinsert(
"SELECT * FROM DATABASE WHERE parameter = '^parameter_value^'");
	show(sql_statement);
        CustomSQL( sql_statement )
    ) << Run;
nw = new window("Example Input for SQL",
	panelbox("Parameter Specification",
		hlistbox(
			text box("Enter value for parameter: "),
			teb = text edit box("", << set width(200)),
	panelbox("Actions",
		hlistbox(
			button box("Cancel", nw << close window),
			button box("OK",
				pvalue = teb << get text;
				if (pvalue == "",
					ew = new window("Error", << modal,
						text box("Nothing specified")
					// else import the data
					importdatapress(pvalue);
					nw << close window;
	Show(sqlString);
	<< set function(
		function({this},
pmroz
    ) << Run;
		hlistbox(
	panelbox("Actions",
		hlistbox(
			button box("OK",
				if (pvalue == "",
					nw << close window;
CSkjodt
Thank you so much, this did the trick :)
