StevenC
import images in xls to jmp
I have a data table in xls which I would like to import to jmp. This data table from a patent search engine is containing a column with a link to the patent pdf and a column with an images from the first page of the patent. I do not manage to get those 2 columns (even as expressions ) into a jmp table.
Thanks
SC
Re: import images in xls to jmp
Hello @StevenC ,
I'm afraid that JMP currently does not provide feature that import image from Excel.
I think the following is a workaround that requires manual procedure.
- Copy and paste a column in Excel that contains an image into a Word document.
- Import an image using the following addins.
https://community.jmp.com/t5/JMP-Add-Ins/Word-Import-Tool/ta-p/41325
I hope it helps.
