PhamBao
how to replace / insert character into double quote of a string
Dear all,
I have a string like this .
<ak:Unit X="0" Y="1" Id="U33">
Do you know how to replace characters in double quotes of a string
For example
<ak:Unit X="0" Y="1" Id="U33">  ==> <ak:Unit X="Default1" Y="Default2" Id="Default3">
Sincerely
7 REPLIES 7
Re: how to replace / insert character into double quote of a string
Substitute (or substitute into) is one option. Just remember to use escape character for double quote.
str = "\[<ak:Unit X="0" Y="1" Id="U33">]\";
result = "\[<ak:Unit X="Default1" Y="Default2" Id="Default3">]\";
new_str = Substitute(str, "\!"0\!"", "\!"Default1\!"", "\!"1\!"", "\!"Default2\!"", "\!"U33\!"", "\!"Default3\!"");
result == new_str;
Given the specifics of the example string
The actual substitute() function can be simplified to
Substitute(str, "0", "Default1", "1", "Default2", "U33", "Default3");
PhamBao
Got it ! thank you a lot
PhamBao
Hi Jthi,
It works!
Same question, but this time how could I substitute characters in a string by variable
For example:
Default1, Default2 and Default3 are now variables and their value would be changed
Here is an example where the first element is replaced from a variables value
str = "\[<ak:Unit X="__one__" Y="1" Id="U33">]\";
sub1 = "theSub1";
mySub = Substitute(str,expr(__one__), sub1, "Default2", "U33", "Default3");
I think fairly rarely you would first add variable names to the string and then start replacing those with the values, but you could do it with Eval Insert.
Better option would be to directly add those values there. Example below has both options, first adds ¤Default1¤ and so on and replaces those by using Eval Insert Into (see scripting index), next one is using Associative array. Associative array is using the strings which are to be replaced as keys and values are the new values (I would use second option).
new_str = Substitute(str, "\!"0\!"", "\!"¤Default1¤\!"", "\!"1\!"", "\!"¤Default2¤\!"", "\!"U33\!"", "\!"¤Default3¤\!"");
Default1 = "test1";
Default2 = "test2";
Default3 = "test3";
Write("Eval Insert into: \!N");
Eval Insert Into(new_str, "¤");
Write(new_str);
Write("\!N\!NAssociative Array:\!N");
aa_replace = Associative Array();
aa_replace["\!"0\!""] = "\!"test1\!"";
aa_replace["\!"1\!""] = "\!"test2\!"";
aa_replace["\!"U33\!""] = "\!"test3\!"";
new_str2 = Substitute(str, aa_replace << get keys, aa_replace << get values);
write(new_str2);
ErraticAttack
If you know the starting tag (in this case, "ak:Unit"), then you can use Parse XML():
ex = "\[<ak:Unit X="0" Y="1" Id="U33">]\";
Parse XML( ex,
	On Element( "ak:Unit", Start Tag( xml = XML Attr() ) ),
xml << Remove( "" );
default 1 = "new X";
default 2 = "new Y";
default 3 = "new Id";
new vals = [=>];
new vals["X"] = default 1;
new vals["Y"] = default 2;
new vals["Id"] = default 3;
new string = "<ak:Unit";
keys = {"X", "Y", "Id"};
For( i = 1, i <= 3, i++,
	new string ||= " " || keys[i] || "=\!"" || new vals[keys[i]] || "\!""
new string ||= ">";
Write( new string )
Jordan
