Mickyboy
Level V
how to replace a numeric value in a variable
Hi All,
this might be very easy so forgive me, i am trying to replace a numeric value in a variable with another value and am trying to do so with the following syntax
Acc << select where( :lo50%expGMT > 10.0 );
Acc << replace (5);
this deletes the whole row rather then replace any values under 10 with 5.
Can anyone help me?????
Re: how to replace a numeric value in a variable
You did not copy the formula correctly.  It is:
Acc << New Column( "lo50%expGMT", Numeric, Continuous, Formula(If(round(:expGMT / 2 ) >= 10,round(:expGMT / 2 ), 5)));
Please review the structure of an IF() clause in the Scripting Guide
     Help==>Books==>Scripting Guide
There are 3 sections to an IF() clause.
     If( comparison, what to do if the comparision is true, what to do if the comparison is not true);
Therefore:
If(     round(:expGMT / 2 ) >= 10 // The comparision
  ,round(:expGMT / 2 ) // What to do if true
    , 5  // what to do if not true
14 REPLIES 14
Assuming that "Acc" is the pointer to the data table, and that "Acc:lo50%expGMT" is the name of the column that you both want to compare with and then change it"s value, the following code will change the values
:Name("Acc:lo50%expGMT" )[Acc << get rows where( :Name("lo50%expGMT") > 10.0 )] = 5;
I choose to use the :Name() function in the code, since the column name contains a special character "%" that JMP may get confused over.
Mickyboy
Level V
Thanks Jim, l really appreciate it, will try it at work tomorrow
Mickyboy
Level V
Hi Jim,
My apologies, l am new to JMP so struggling a little bit with the Syntax, this didnt work either, Acc is the pointer to the data table "Accuracy" and the name of the variable is lo50%expGMT.
Oops...I had an error...try this
Acc:Name("lo50%expGMT" )[Acc << get rows where( :Name("lo50%expGMT") > 10.0 )] = 5
Mickyboy
Level V
Sorry Jim, still didnt work
Mickyboy
Level V
l think the problem is that the variable lo50%expGMT has a formula and is derivied by dividing another variable by 2, would this matter??
The fact that lo50%expGMT is a column created with a formula will not make any differenct
What messages are you seeing in the log?
If you run just the following JSL, you will see the results in the log.  It should just give you a matrix with the row numbers for all of the rows where lo50%expGMT is greater than 10
Acc << get rows where( :Name("lo50%expGMT") > 10.0 );
 Can you  attach a sample data table?
Mickyboy
Level V
1 12 10.684 1645 1645 823 3290 Pass
2 12 9.4540 701 823 412 1646 Pass
4 12 8.4053 339 411 206 822 Pass
8 12 7.4053 170 206 103 412 Pass
16 12 6.4053 85 103 52 206 Pass
32 12 5.3707 41 51 26 102 Pass
64 12 4.3707 21 26 13 52 Pass
128 12 2.4886 6 13 7 26 Fail
it hasnt selected the row in question, the one in question is the last row, the variable in question is lo50%expGMT, which the forth from the left.
Mickyboy
Level V
Sorry that should be the 6th from the left
