cremebrulee
how to pass string list to Group Scripts in jsl
Hello all,
I've been trying for a couple of days to figure out if there's a way to pass a list of string variable to Group Scripts with the group name. Whenever I do that I got the log error message of "Group command needs to specify a list of scripts to be grouped" with the code below.
ChartList={"Script_1","Script_2","Script_3"};
DataTable_result << Group Scripts("AllCharts",ChartList);
If I change my code to below, the code run fine.
DataTable_result << Group Scripts("AllCharts",{"Script_1","Script_2","Script_3"});
I intend to make my code reusable by user define the script names that need to be grouped.I have tried a couple other things, such as using the eval(), expr(), but they don't work. Anyone has any suggestions, that would be great. Thanks in advanced.
Cremebrulee
Re: how to pass string list to Group Scripts in jsl
I have validated your findings.  However, the script below will allow for the grouping to work.
Eval(
	Substitute(
			Expr(
				dt << group scripts( "AllCharts", __chartlist__ )
		Expr( __chartlist__ ), chartlist
I suggest that you submit the issue to JMP support as a bug.
Eval(
	Substitute(
			Expr(
cremebrulee
Thank you so much.
