OneNorthJMP
how to multiple column format at once
When i import numeric percentile data by copy and paste. It automatically trim to 0 decimal. Is that possible i can change all columns at once to 2 decimal point?
Re: how to multiple column format at once
This one is easy. Select all the columns that you want to format. Select Cols > Standardize Attributes. Click Attributes and select Format. Change the Format to the one that you want (Percent). Click OK.
OneNorthJMP
Thanks for the great tips!!
gallardet
Simple and fast. Thank you very much
