how to multiple column format at once in JMP Script I have them in a column group and all should be Fixed Dec, 15, 0 -thanks
Re: how to multiple column format at once in JMP Script I have them in a column group and all should be Fixed Dec, 15, 0 -thanks
Select the columns you want to change the format to, then go to the pull down menu
     Cols=>Standardize Attributes
and you will be able to set the format once and it will apply it to all of the selected columns.
Georg
In addition to interactive way of Jim, to do it as a Script see the following example:
// define a column group and set format of that columns in the group
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
dt << group columns( "decimals", {:height, :weight} );
For Each( {value}, dt << get column group( "decimals" ),
	Print( value );
	value << Format( "Fixed Dec", 15, 3 );
Georg
Georg
	Print( value );
Georg
Thanks for your help
