how to extract certain bits from a string hex column to number ?
Hello, Gurus,
I have a very simple question on how to extract certain bits from a string hex column(named Flags) to numbers. My column values will be like "0x1BA1". I would like to extract the bits 8 and 9 values and convert them to a value of 3 into my new column. Since I don't know the binary operation in jmp, I tried to extract B into 11 first by doing the following
Char To Hex(Munger(:Flags, 4, 1)).
It gives me a character column of 42. I tried to put a "integer" in to the formula
Char To Hex((Munger(:Flags, 4, 1)), "integer")
But it wouldn't recognize it. I'm using jmp11.2.1.
After extracting B, I'll use module(module(value,8),4) to get the lower 2 bits.
If there's an easy way to extract binary bits, that will be even better.
Thank you,
Jane
ms
Super User (Alumni) ms
Re: how to extract certain bits from a string hex column to number ?
As Craige pointed out (thanks, I was not aware), JMP 11 requires an even number of hex characters.
Try this formula for single character substrings:
Hex To Number("0" || Substr(Flags, 4, 1));
6 REPLIES 6
ms
There is a function Hex to Number() that converts hexadecimal numbers (as strings) to decimal numbers.
Example:
hex = "0x1BA1";
// Hex to decimal
value = Hex To Number(Substr(hex, 4, 1));
Show(value);
// decimal to binary
bin = "";
While(value,
    bin = Char(Modulo(Num(value), 2)) || bin;
    value = Floor(value / 2);
Show(bin);
// Reverse last step for confirmation (or just for fun)
value2 = Sum(2 ^ (Loc(Reverse(Words(bin, "")), "1") - 1));
Show(value2);
Craige_Hales
before JMP 12 you'll need an even number of hex characters:
Hex To Number( "0B" )
11
Craige
Hi, Craig,
Thank you. The magic "0" in front of "B" is the key.
Jane
Hello, MS,
I have trouble with these "Hex to .." command. They don't work on my case. Here's the screen copy. I don't know what could be wrong.
Thank you,
Jane
ms
Thank you, MS.
I tried the concat "0" and it works.
Jane
