how to delete or show log window using JSL
I need how to delete or show log window using JSL.
Thanks,
Clark
mpb
mpb
Re: how to delete or show log window using JSL
Main Menu("Log") toggles display of the log.
Clear Log() clears the log.
mpb
mpb
main Menu("log") has a problem.
Onec I don'g make log window, Main Menu("log") make log window.
I'd like to control it to show log window always by main Menu function.
Can I do it by JSL?
Message was edited by: clark(woo-seag)
cakinli
Whether or not the log window exists, it can be referenced. This works for me:
Window("Log") << ShowWindow
Additionally, I've found that once it's been shown in a JMP session and closed, anything that causes output to it will cause it to reappear, including a call to ClearLog().
-Cengiz
> log window.
> main Menu function.
> Can I do it by JSL?
