lujc07
how can I use structural equation model to make predictions?
I built a structural equation model and it works well. I would like use the model to make some predictions. Basically, what I want to do is to change the value of a variable and then JMP can calculate the values of other variables. Is there any way i can output the model equation so that I can use it to predict? Thanks.
0 REPLIES 0
