how I can add standard deviation of two repeats in the fitted curve
I am trying to build a growth curve based on two repeats I created the graph using graph builder and when I tried to analyze the graph to do curve fitting using Gompertz model it separates the two repeat again instead of the mean and I can not add the standard deviation to each data point how I can fix that?
0 REPLIES 0
