vince_faller
get rows where and select where
I'm seeing a weird issue with get rows where when trying to make it dynamic.
dt = Open("$SAMPLE_DATA\Big Class.jmp");
dt << get rows Where(:Sex == "F"); //Works
dt << Get Rows Where(Column("Sex") == "F"); // Doesn't Work
//but ...
col = :Sex; //doesn't work
col = Column("Sex"); //Works
//so trying to do
dt << Get Rows Where (col == "F");
//can't work in any way that I can see
Tried a few different versions.  Anyone else getting this?  I swear I've done this before.  I tried :Name as well but it doesn't like using a variable and doing some type of Eval seems pretty hacky for this.
Vince Faller - Predictum
ms
Super User (Alumni) ms
Re: get rows where and select where
An empty index appears to be needed to access the data of a column when the current row is implicit. Alternatively As Column() can be applied to a column name (as string) or a variable.
dt << Get Rows Where(Column("Sex")[] == "F"); // Works
dt << Get Rows Where(col[] == "F"); // Works
dt << Get Rows Where(As Column(col) == "F"); // Works
dt << Get Rows Where(As Column("sex") == "F"); // Works
vince_faller
I could do
col = Column("Sex")<<Get Values;
Loc(col,"F");
But I still think something within the data table should work.
ms
vince_faller
Yep.   Column("Sex")[row()] was how I was doing it before.
Thank you
pmroz
One more wrinkle.  I use strings for the column names, rather than pointers to the column.  This works:
col = "Sex";
srows = dt << get rows Where(as column(dt, col) == "F");
This works too:
srows = dt << get rows Where(as column(col) == "F");
ram
ram
better solution;
col1="height"; val="61"; val2="95";
srows = dt << get rows Where(char(column(col1)[]) == char(val) );
