dadawasozo
Level V
get rows in between characters from a column then move other column value (selected row only) to other column
I want to move or copy paste multiple column value of selected rows to other columns in the same table like picture below
the interested rows are always start from :Item == "start" until :Item == "values", but the total rows can be different. I want to copy paste or move value in Col1 and Col2 of the interested rows to Col 3 and Col 4. My current thought is to manually create a list that include the string from start to values under :Item then create a column to label as "1" if :Item contains list. from there set the Col 3 == Col 1 and Col 4 = Col 2.
However, the rows between start and values can be different. I wonder if anyone know better method to do the task without the need of manually create the list, but based on the "start" and "values" to find the rows.
original table
 after moved
mmarchandFSLR
Re: get rows in between characters from a column then move other column value (selected row only) to other column
I think you can safely do it without a config table.  This checks to make sure that Col 1 contains a value in the "start" row before overwriting anything.  Yes, I like using For Each().
starts = Loc( dt:Item << Get Values, "start" );
ends = Loc( dt:Item << Get Values, "values" );
For Each( {v, i}, starts,
	If( :Col 1[v] != "",
		For Each( {val, idx}, v :: ends[i],
			:Col 3[val] = :Col 1[val];
			:Col 4[val] = :Col 2[val];
			:Col 1[val] = "";
			:Col 2[val] = "";
I suspect it would be easier to manually do the cut and paste rather than having to create start and stop lists.
dadawasozo
Level V
but the purpose is for daily automation and the rows between the start and values can change from time to time.
Then I would make it as straight forward as possible and create a config table something like
Which makes your JSL pretty simple, something like:
dt = Current Data Table();
dtConfig = Data Table( "Config" );
For( i = 1, i <= N Rows( dtConfig ), i++,
	frCol = dtConfig:From Column[i];
	toCol = dtConfig:To Column[i];
	For( k = dtConfig:Start Row[i], k <= dtConfig:End Row[i], k++,
		Column( dt:toCol )[k] = Column( dt, FromCol )[k];
		If( dtConfig:Move_Copy == "Move",
			Column( dt, FromCol ) = ""
mmarchandFSLR
			:Col 1[val] = "";
			:Col 2[val] = "";
