Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
How do I get a whole model significance test when conducting a generalized regression using the negative binomial distribution? I can get the individual effect significance tests, but I do not see where I can get the whole model significance.
