dadawasozo
Level V
find unique strings separated by comma for each row in a column and count the total recurrence
I wonder if there is a way to create column with formula to find unique strings separated by comma in a column and count total recurrence of each like below?
Re: find unique strings separated by comma for each row in a column and count the total recurrence
Here is one way of handling this
Unique Item formula
x = Words( :Input, "," );
For Each( {element, index}, x, x[index] = Trim( element ) );
x = Associative Array( x ) << get keys;
x = Concat Items( x, "," );
Total Recurrence formula
theList = Associative Array( x ) << get keys;
value = "";
For Each( {element}, theList, value = value || "," || Char( N Rows( Loc( x, element ) ) ) );
Substr( value, 2 );
Unique Item formula
value = "";
Substr( value, 2 );
dadawasozo
Level V
Hi Jim,
it looks like both formula is same
My error......I corrected my initial post to the correct formula
dadawasozo
Level V
Thank you for the helps!!!
