dynamic Y variable for oneway analysis
Hi everybody,
I am trying to script a dynamic Y variable for oneway analysis, then output the mean into a combined table. Is this a correct way to do so ?
dt = Data Table ("Analysis");
ColNamesList = d1 << get column names (string );
For( i = N Items( ColNamesList ), i >= 1, i--,
OW = (dt << Oneway( Y( Column(ColNamesList) ),
	   X(:SITE),
	   Mean ( 1 ),
	   Automatic Recalc( 0 )
	 )) << Report;
dtCombined = Report( OW[1] )[Table Box( 1 )] << Make Combined Data Table;
Thanks in advance !
pauldeen
Re: dynamic Y variable for oneway analysis
Run it: is it working for your table?
If yes, this is a correct way to do it!
If not, let us know where you run into trouble?
Sorry, I accidentally clicked on the solution button.
The script did not prompt any error. But, there was also no graph seen as an output.
The script log only shows scriptable.
Georg
Dear @XiangCD_MP_User , I had several issues with your script. If I got your task, it is doing a oneway analysis for each continuous column of the data table by :site, and saving the data table with the mean.
If so, I would do it like follows:
Alternatively there are other possiblities, e.g. putting all together in one "Fit Group" statement. The best way depends on your scripting skills, and what exact environment it should run in.
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
// dt = Data Table ("Analysis");
OW_lst = {};
ColNamesList = dt << get column names( string, "Continuous" );
// When using single report windows, you would need to collect the result table from each of them
	Insert Into( OW_lst, dt << Oneway( Y( Column( ColNamesList[i] ) ), X( :sex ), Means( 1 ), Automatic Recalc( 0 ) ) )
// Generate new report window to collect all analyses
nw = New Window( "Oneway Collection",
	hlb = H List Box(
		// collect references to each analysis in OW_lst
// Message will collect all similar tables in one data table
dtCombined = Report( OW_lst[1] )[Table Box( 1 )] << Make Combined Data Table;
// Alternatively you would be able to get the same result w/o working with a list like follows
//(nw << XPATH( "//TableBox" ))[2] << Make Combined Data Table;
Georg
@XiangCD_MP_User ,
You might try using Response Screening under the Analyze>Screening menu.  You can still pass in the list of column names into the Y variable place holder. The output of Response Screening will allow an option in the red triangle to save means for each X level or a Pvalues table that has the mean for each Y.
Also, if you find all of the columns that match a string and put them into a list (which looks like what you are doing), you can use the variable name (using Eval()) within the Y variable of Response Screening. Or you can group them into a column group and reference the column group within Response Screening. Effectively it will do the loop like you want and it is dynamic.
Something Like:
dt = Open( "$SAMPLE_DATA/Probe.jmp" );
dt << Response Screening(
	X( :Process ),
	Y( Column Group( "Responses" ) ),
    PValues Table on Launch( 1 ),
	Save Means
This outputs the p-values as well as the mean of Y for each comparison.
Chris Kirchberg, M.S.2
www.jmp.com
