dot instead of coma
Hi, how can I change the coma by dot in my numeric values, ie how to display 1.6 instead of 1,6 for example. My graphics need to have "."
Thank you
XanGregg
dot instead of coma
Are these numbers from JMP or numbers you are showing from a script? In the latter case you have more control, but either way, JMP is looking to the OS regional settings for how to display numbers. There is a JMP Preference on Windows to override the OS locale.
