maryam_nourmand
data preprocessing
Hello.
My question is when we use nonparametric model in software such as neural network or SVM or Naive bayes or ....do the software scale our data by default?or before we use these models we should scale our numeric data?
Victor_G
Re: data preprocessing
Ok, but in my (very long) answer, I did mention about tree-based methods and Naive Bayes:
Tree-based models and probability-based algorithms like Naive Bayes may not require scaling.
Tree-based methods don't require scaling as they are are not distance-based algorithms, the splits are done based on the order of the data and information generated by splitting at a certain threshold, but there are no influences of the individual values, ranges or distributions on the split results.
Naive Bayes is a probability-based algorithm, it calculates probabilities from the data's distribution and is invariant to the scale of the data.
Some further ressources :
https://stats.stackexchange.com/questions/244507/what-algorithms-need-feature-scaling-beside-from-sv...
https://www.dataschool.io/comparing-supervised-learning-algorithms/
https://forecastegy.com/posts/do-decision-trees-need-feature-scaling-or-normalization/
Does this complementary response answer your question ?
Victor GUILLER
Victor_G
Hi @maryam_nourmand,
Did you read my reply to one of your similar question : https://community.jmp.com/t5/Discussions/data-preprocessing/m-p/761840/highlight/true#M93976 ?
Victor GUILLER
maryam_nourmand
Yes i read
but you mention about (( SVM, KNN, Neural Networks, (linear & logistic) regression))
i actually want to know about other models
boosted tree
bootstrap forest
decision tree
Naive bayes
thanks
Victor_G
Victor GUILLER
maryam_nourmand
Thanks a lot
