tova
creating a journal in a new window with hlist and vlist boxes with a for loop
Hi. I would like to create a script that creates a new journal with a variable amount of oneway graphs arranged in the way I want.  I have tried multipe ways and cannot figure it out.  Can someone help me?  Thanks!
Trying to write something like this:
Hlist_MSG1 = "HList Box(( oneway_List[";
Hlist_MSG2 = "] << Report) << Clone Box, ( noz_stat[";
Hlist_MSG3 = "] <<Report)[";
Hlist_MSG4 = "] << Clone Box)";
nw = New Window(name, <<Journal,
vlb = V List Box(
for(i=1, i<=n_Copies, i++,
evallist({Hlist_MSG1,
i;
Hlist_MSG2;
i;
Hlist_MSG3;
1;
Hlist_MSG4;
if(i<n_Copies,", ", " ")}));
Or like this:
HLIST_MSG_LST[i] = "HList Box(( oneway_List[" || char(i) || "] << Report) << Clone Box, ( noz_stat[" || char(i) || "] <<Report)[1] << Clone Box)");
subs_list = {};
for(i=1, i<=n_Copies, i++, subs_list [i] = "num("||char(i)||")");
num_list = {};
for(i=1, i<=n_Copies, i++, num_list [i] = i);
vlb = V List Box(
eval(parse(substitute(HLIST_MSG_LST[i],subs_list[i],num_list[i])));
if(i<n_Copies,", ", " "));
Re: creating a journal in a new window with hlist and vlist boxes with a for loop
Here is a methodology that I have found to be much easier to build outputs with.  I believe it goes after what you are trying to do, but it is simplert to work with, and easier to follow.
dt = Open( "$SAMPLE_DATA\Semiconductor Capability.jmp" );
// Create some structures to hold the results
mainBox = V List Box();
theHBox = H List Box();
// Get the column names for the analysis
colList = dt << Get Column Names( continuous );
// Loop across the columns and generate the analyis, placing
// 4 analyses into an H List Box(), and then when all 4 are
// in the H List Box(), add it to the main V List Box();
For( i = 1, i <= 25, i++,
	theHBox << Append( oneway( y( colList[i] ), x( :Site ) ) );
	If( Mod( i, 4 ) == 0 | i == 25,
		mainBox << Append( theHBox );
// Now create the journal to hold all of the results
nw = New Window( "Results", <<journal, finalBox = H List Box() );
// Add the accumulated analyses to the journal
finalBox << Append( mainBox );
tova
Thanks Jim,  I won't be able to try and implement this until next week, so I will update then.  But this looks like it should help me.
tova
never mind, it was easy to implement, so I don't need to wait until next week to see if it works.
It works.
Thank you!!
