correlation plot
Hi I want to make a correlation plot for between 2 fixture, could you please help how to do it step by step to analysis the correlation plot
Victor_G
Re: correlation plot
Hi @anurudh_palla,
Welcome in the Community !
The easiest option to do a correlation map/scatterplot matrix is to use the Multivariate platform. You can find an example on how to use it here : https://www.jmp.com/support/help/en/18.1/#page/jmp/example-of-the-multivariate-platform.shtml#ww3858...
Select simply all the variables you want to see in the correlation map and scatterplot matrix, and launch the platform : https://www.jmp.com/support/help/en/18.1/#page/jmp/launch-the-multivariate-platform.shtml#ww141062
Note that you can also do it "manually" by using Graph Builder platform and display your variables in X and Y axis. Using Ellipse, you can display correlation coefficient : https://www.jmp.com/support/help/en/18.1/#page/jmp/ellipse.shtml#ww662778
Hope this answer will help you,
Victor GUILLER
statman
Victor has given you the options.  The question I have is regarding the data type of your "2 fixture".  If the "2 fixture" is categorical, then you can't do Pearson correlations.  There are non parametric correlations:
https://www.jmp.com/support/help/en/18.1/?os=mac&source=application#page/jmp/multivariate-platform-o...
