mvanderaa1
convert number to datetime with milliseconds
Hi, I have a column with values of the following format: '20230818103947300000'
I was hoping to be able to convert it using the custom format (i.e. <YYYY><MM><dd> etc), but I do not see the option for milliseconds. Of course I can make a long formula to extract each individual element and then adding them together, but I really want to avoid that.
For reference, in python I am able to do this in one line to get my datetime object dt:
from datetime import datetime
d='20230818103947300000'
dt=datetime.strptime(d,'%Y%m%d%H%M%S%f')
Re: convert number to datetime with milliseconds
Seems like you have to have "." as separator within seconds
str = "20230818103947300000";
Insert Into(str, ".", Length("YYYYMMDDHHMMSS") +1);
date_formatted = Informat(str, "Format Pattern", "<YYYY><MM><DD><hh24><mm><ss>");
date_with_ms = Format(date_formatted, "yyyy-mm-ddThh:mm:ss", 25,3); // "2023-08-18T10:39:47.300"
