emorris1000
concatenating a variable into a python string
Its been a while since I've really messed with this stuff, but having some issues with the Python Submit function.   Take the following code
Python Init();
Python Submit( "\[
str = 'The quick brown fox jumps over the lazy dog';
a = 200;
getStr = Python Get( str );
getNum = Python Get( a );
Show( getStr, getNum );
Python Term();
If I wanted to make the word "fox" a variable I would have thought it was just a matter of concatenating a variable into the string, but for whatever reason I can't seem to break that string?  Maybe it's because it's a list of strings?   I feel like this is an obvious one but for whatever reason I'm missing it.
pmroz
Re: concatenating a variable into a python string
Maybe something like this?
fox = "python";
Python Init();
Python Submit( evalinsert("\[
str = 'The quick brown ^fox^ jumps over the lazy dog';
a = 200;
Python Term();
I assume you are not using JMP18 (but it shouldn't matter). I'm not sure what issue you are having? You are sending one string and one numeric value to Python and then printing them in JMP which should work fine.
JMP18
pmroz
fox = "python";
Python Init();
a = 200;
Python Term();
emorris1000
That appears to do it.  Any idea why it uses the carrat for that as opposed to just escaping with quotes?
EvalInsert is a JMP JSL function that uses ^ as the default delimiter for the insert.  Here is the JMP Scripting Index entry for the description of the function
The substitution of Fox is performed in JMP before being passed to Python
pmroz
You could also do it this way:
fox = "python";
Python Init();
str = 'The quick brown " || fox || " jumps over the lazy dog';
a = 200;") );
Python Term();
evalinsert offers a cleaner method, IMHO.
