calculates the number of weekdays (Monday to Friday) between two date columns (Start Date and End Date)
Feb 28, 2025 08:27 AM(2601 views)
Hello Community,
I want to create a column formula in JMP 18 that calculates the number of weekdays (Monday to Friday) between two date columns (Start Date and End Date). Weekends (Saturday and Sunday) should be excluded. The formula must be compatible with JMP's column formula editor and should not produce any errors. I don't use JSL
Here are few formulas (no idea about their performance). Some slight adjustments might have to be done depending on how you wish to calculate the difference between two dates
Using Summation
Summation(i = 0, Date Difference(:start, :end, "day"),
!(Day of week(:start + In Days(i)) == 7 | Day of week(:start + In Days(i)) == 1);
Using matrix + sum
Sum(1 < Day of week(:start + (0::Date Difference(:start, :end, "day")) * In Days(1)) < 7)
Using Summation
Using matrix + sum
Give this a try. Just make sure to change the column names at the bottom to the names you have in your data table.
Thanks,
Ben
Names Default to Here(1);
dt = Current Data Table();
//Wipe the old weekday count column if it exists from this script being ran
try(dt:Weekdays Count<<set selected;dt<<delete columns(););
// Add a new column to store the number of weekdays
dt << New Column("Weekdays Count", Numeric, "Continuous");
// Define a function to calculate weekdays between two dates
calcWeekdays = Function({startDate, endDate},
{default local = 1},
weekdays = 0;
startDate = Date MDY(Month(startDate), Day(startDate), Year(startDate));
endDate = Date MDY(Month(endDate), Day(endDate), Year(endDate));
for(i = startDate, i <= endDate, i++,
if(Day Of Week(i) != 1 & Day Of Week(i) != 7, // Exclude Sundays (1) and Saturdays (7)
weekdays++;
weekdays;
// Apply the function to each row - Convert to days with 86400 - //MAKE SURE TO CHANGE THE COLUMN NAMES HERE TO THE CORRECT TYPE
For Each Row(
:Weekdays Count = (calcWeekdays(:Start Date, :End Date)/86400);
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '844970' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '844970') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '844970') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
